configure ospfv3 spf-hold-time
configure ospfv3 spf-hold-time seconds
Description
Configures the minimum number of seconds between Shortest Path First (SPF) recalculations.
Syntax Description
spf-hold-time SPF hold time.
seconds Specifies a time in seconds. The range is 0 to 300 seconds.
Default
3 seconds.
Usage Guidelines
Setting the interval too high will force OSPFv3 to run SPF calculations less frequently. This will reduce the CPU load, but will cause delay in routes getting updated in the IPv6 routing table. Setting the interval too low will decreases the interval between SPF calculations, but will increase the processing load on CPU.
The following command configures the minimum number of seconds between Shortest Path First (SPF) recalculations:
configure ospfv3 spf-hold-time 6
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
